Versa 3 stuck on Fitbit Logo
ANSWERED
HI. My Versa 3 is not powering up. I am not able to do a hard boot also. The logo flashes if I press the button but does not power on, help!!
1 BEST ANSWER
Accepted Solutions
Hello there, @AnupamaAgarwal. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 prior to contacting us.
Please note the issue you're having comes from performing a factory reset without first unpairing your Fitbit device from your Fitbit account and phone's Bluetooth settings. With that being said, I suggest following the steps below in the order listed:
  • Unpair your Versa 3 from your phone's Bluetooth and also make sure it's no longer connect to your Fitbit app.
  • Force quit the Fitbit app.
  • Turn off the Bluetooth.
  • Turn on the Bluetooth.
  • Set up your Versa 3 again.
  • If there is no connection, restart your Versa 2.
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
3 REPLIES 3
Hope that helps.
Hi!
Thank you so much for your help. My fitbit versa 3 has started again!!
Have a great day!!
@AnupamaAgarwal Awesome! I'm glad to hear you're back on track. 😊
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
