Versa 3 stuck on Fitbit logo
ANSWERED
I restarted my versa 3. It won't restart. the fit bit logo appears and disappears every 5 seconds
1 BEST ANSWER
Accepted Solutions
Hi there, @Alva76. Thanks for stopping by in the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
Please note this issue comes from performing a factory reset without first unpairing your Fitbit device from your Fitbit account and phone's Bluetooth settings. With that being said, I suggest following the steps below in the order listed (or making sure you've done them as instructed):
  • Unpair your Versa 3 from your phone's Bluetooth and also make sure it's no longer connect to your Fitbit app.
  • Force quit the Fitbit app.
  • Turn off the Bluetooth.
  • Turn on the Bluetooth.
  • Set up your Versa 3 again.
  • If there is no connection, restart your Versa 3.
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
1 REPLY 1
