10-20-2023
12:06
13:42
10-20-2023
12:06
13:42
My Fitbit versa 3 is stuck on the logo. It will vibrate and show the logo and then disappear vibrate and show logo again. Seems to be stuck in this loop and not able to do anything else
10-20-2023 13:52
10-20-2023 13:52
Hi there, @Alibongo07. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
If you haven't done so yet, I'd recommend trying the steps below in the order listed:
Before trying the above, please be aware that most Fitbit devices store up to 7 days of detailed minute-by-minute data. If you wait longer than 7 days before syncing, you may only see the most recent week's detailed data. Summary data (calories, distance, steps, and floors) will be stored for 30 days. Nevertheless, if your Fitbit device was unpaired from your Fitbit account during this period of time, neither the 7 days can be recovered or restored.
Hope this helps!
10-21-2023 09:08
10-21-2023 09:08
@MarreFitbit , You seem to be posting the same standard answer and not really reading the problem. I have tried that procedure already from the many other times that you have posted it. The problem is that the Fitbit Versa 3 is NEVER resetting, it only returns to the logo and stops.
As so many other people have reported the same problem around the same time, can you provide some other details as to why this happened now? Is there a procedure to do a hard reset or factory reset that does not include connecting to the Fitbit app or getting to the settings screen on the device?
10-21-2023 17:50
10-21-2023 17:50
I have the same issue, this did not solve the problem. What next?
10-22-2023 04:49
10-22-2023 04:49
I have the same issue. Only bought it in August and it only stayed synced to my phone for about 3 weeks 😢
10-22-2023 13:42
10-22-2023 13:42
Hello,
this did not fix the issue and the versa 3 is still stuck in the same loop. Can you please advise what to do next as it is less then a year old
10-23-2023 06:14
10-23-2023 06:14
I have the same isse
10-23-2023 06:18
10-23-2023 06:18
This does not help. My fitbit is stuck on that logo loop. It cannot be reset or turned off. I've tried your steps mentioned above and it does not work. Please provide next steps
10-23-2023 12:46 - edited 10-23-2023 12:50
I'm dealing with this exact issue, I chatted with the Live Chat and the person who I was talking to just didn't get it. That all I see is the logo, nothing else. They said they would review my case and get back to me. It's been 20 days.
I this is the second Fitbit that I cannot use, I returned my ionic after the recall and purchased the Versa3 and now thats not working.
Get your S**T together Fitbit!
10-23-2023 14:20
10-23-2023 14:20
I called, they walked me through the factory reset, and still stuck.
This is also my second fitbit. The Versa 2 stopped working after 2 years and it was out of warranty, this one was 1 year, and of course I got it from an unauthorized seller on Amazon so no warranty at all.
I love the app, but Apple Watch might be a better choice next time.
10-24-2023 02:28
10-24-2023 02:28
My Versa 2 just did the same. I found this website & it worked. Try it on the Versa 3 if it doesn't work search it on a browser.
https://www.myhealthyapple.com/is-you-fitbit-stuck-on-the-fitbit-logo-lets-fix-it/
10-24-2023 10:31
10-24-2023 10:31
Thanks for sending that. Unfortunately I've not even been able to connect my versa 3 to my phone so the only thing I can do is restart and the same keeps happening. At least I know it's a fault with these, not good enough though
10-24-2023 10:59
10-24-2023 10:59
And when I go to connect it, it goes up to pairing code then just doesn't pair. I've heard this has happened since the new app update
10-25-2023 00:24
10-25-2023 00:24
Do try these steps. Do all at once. I did and it got mine working. Good luck.
10-25-2023 00:26
10-25-2023 00:26
Try going to main fitbit screen and pulling screen down that's how you sync the watch with the app. I do this each morning when I wake up.
10-25-2023 00:27
10-25-2023 00:27
I would let the watch run flat. Fully charge again the start it. Go through procedure above to load app to watch.
10-25-2023 00:31
10-25-2023 00:31
Did you let the watch ru flat first. Then try fitbit steps above. Do all of them at once.
Make sure all other bluetooth devices are unpaired, also do this set-up over WiFi. Doesn't work over just mobile data.
10-25-2023 00:32
10-25-2023 00:32
Thanks but I haven't even got it connected to my phone yet. It's new and I've not been able to connect it. It goes to the pairing code then it just doesn't connect. I've tried everything
10-25-2023 00:45
10-25-2023 00:45
Exactly what was happening to me.
Unpaired all other Bluetooth devices with your phone.
Make sure your connected to WiFi.
Download the fitbit app to your phone.
I'll copy the steps for you under this comment.
Hang in there. It will eventually connect. Lol
10-25-2023 01:03
10-25-2023 01:03
