04-07-2021
12:19
20:47
04-07-2021
12:19
20:47
Can anyone please tell me how I can stop continually getting the notification to set up my wallet? It doesn’t accept my card, so I cannot do it, however, every single time I look at my screen it notifies me to set up my wallet and I have to clear it 😞
thank you in advance for any help.
Tracy
04-09-2021 05:52 - edited 05-20-2024 02:45
Hi there, @TracyFace82. Welcome to the Community Forums. Thanks for sharing the details about the issue with your Versa 3. I understand how you must be feeling.
Usually that screen will appear when opening the wallet app on your watch by either tapping on it or with left button to access to the shortcuts. While it's not possible to delete the wallet app, please give a try to the following steps to reconnect your watch to your account:
04-09-2021 11:36
04-09-2021 11:36
Since you are not able, for now, to use wallet let's remove the wallet app from the quick menus.
On your Versa 3 let's swipe to settings, tap, then swipe to shortcuts.
It is here where the user can configure what a single and double tap of the button will open. Replace the wallet for some other function.
Hopefully your bank will add fitbit pay soon, have you enquired about this with your bank @TracyFace82
07-17-2021 16:01
07-17-2021 16:01
This is not the best answer. please see Rich_Laue's post from 04-09-2021 11:36.
07-17-2021 16:01
07-17-2021 16:01
I was losing my mind until i saw your post, thank you for sharing!!!!
07-17-2021 16:02
07-17-2021 16:02
07-17-2021 16:04
07-17-2021 16:04
Rich_Laue's post from 04-09-2021 11:36. was the most helpful post.
I did not have to waste my time resetting my fitbit and bluetooth connections to get the messaging to stop as the "Best Answer" described.
11-28-2021 16:15
11-28-2021 16:15
This, without a doubt, the dumbest thing I ever heard. I DO NOT want to use Fitbit pay period! It is getting to the point were I'm going to switch to Apple. I just want the darn watch to STOP asking me to setup my wallet. I want to see whet time it is, not be the target of a nagging piece of electronic gear!
11-28-2021 16:54
11-28-2021 16:54
Santa is getting me a Apple Watch because of this issue.
12-19-2021 06:03
12-19-2021 06:03
Please sticky the solution to this problem.
Go to settings and modify your shortcuts on what happens when you tap each corner of the watch and pick something else besides wallet.
Fitbit should take the wallet off as default.
12-19-2021 09:31 - edited 12-19-2021 09:35
@MKE2SAILORS then remove the wallet shortcut from the menu.
@ArmySoldier this thread has an answer to the original question. Your answer is not about how to get out of the setup wallet, your explaining how to remove the wallet.
The person that made the original post is responsible to mark the best answer.
@Nouhope then you will be dealing with Apple asking you to setup their wallet.
12-19-2021 11:40
12-19-2021 11:40
Thanks Rich for your concern, I hope you have a great Christmas 🙂
I look forward to exploring my new Apple Watch functions like, seeing the time and receiving text messages.
12-26-2021 13:28
12-26-2021 13:28
How do we stop this notification without uploading a card? I have zero interest in uploading a card, and it vexes me that I have to upload a card in order to see the time vs the unnecessary reminder.
12-27-2021 08:46
12-27-2021 08:46
The easiest way I know of @Hedden is to go into settings and remove the wallet from the quick setting.
If a user doesn't request the wallet, they will not get the message to setup the wallet.
01-17-2022 18:32
01-17-2022 18:32
Let us delete the wallet. This is a shockingly stupid solution.
01-18-2022 01:15
01-18-2022 01:15
I would search the Feature Suggestion board, their may already be this request, or you can create a request. Asking the community of fitbit users to redesign your firmware
02-20-2022 05:19
02-20-2022 05:19
Agree. That worked for me.
02-20-2022 07:15
02-20-2022 07:15
This has not worked for me. I have NEVER requested the wallet, I would never consider it, and I did not accidentally make a request. Do not ever indicate on the user boards that we took actions that caused our own problem. This is a new design on the Fitbit.
05-08-2022 04:54
05-08-2022 04:54
You cannot remove the wallet from your apps which is ridiculous
05-08-2022 07:24 - edited 05-08-2022 07:28
That is true @Jengch but as mentioned, we can remove Pay from both button quick starts. Once these are removed, the user will not be able to, even accidently, open Fitbit Pay.
