08-02-2023 12:17
08-02-2023 12:17
My versa 3 is stuck on a constant restart loop for 48 hours. I unpaired the device abd restarted it so many times. I just keep getting a fir bit logo when I restart it. I just got this watch in February. There is no reset button that I can see. I can't do anything with it in the app since it is no longer paired and can't get past the fitbit logo.
08-02-2023 14:04
08-02-2023 14:04
Good to see you as a new member in the community @Sasharochelle.
Thanks for the details provided regarding the issue with your Versa 3 and the attempts to solve it.
Please try the following steps:
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Best Answer08-02-2023 16:37
08-02-2023 16:37
I am having this exact issue. It’s as though the button is being held down so the Fitbit thinks it’s being restarted. But obviously the button is only a sensor so I’ve no idea how to resolve this. Does anyone have advice for returning a faulty Fitbit?
