01-30-2021
00:04
20:47
01-30-2021
00:04
20:47
Hello,
The battery is totally empty. I have it attached to the charger. It is not showing me progress, and when I firmly hold it to the charger it sometimes shows me a battery logo at 0% for 2 seconds. It has been on the charger (directly on a 2A USB charger) for 24+ hours now.
What could be wrong here?
Jeroen
01-30-2021 01:23
01-30-2021 01:23
Have you checked if the small (brass) connectors on your watch are clean?
It looks like your watch only starts charging when you firmly press it, which may be caused by a faulty connector or a dirty watch connection...
01-30-2021 01:23
01-30-2021 01:23
01-30-2021 02:10
01-30-2021 02:10
Any suggestions as to with what to clean these?
01-30-2021 02:40 - edited 01-30-2021 02:41
Hi there @Jeroen1971, welcome to the Community Forums. Thanks for sharing the details about the issue with your Versa 3.
As @chielmi has recommended, check if the pins on the device or charging cable are dirty. For more information on how to do so, see Why isn't my Fitbit device's battery charging?
Let me know how it goes.
01-30-2021 04:01
01-30-2021 04:01
Cleaning worked - thanks. I wiped it before, but did a more thorough job this time 🙂
01-30-2021 04:03
01-30-2021 04:03
@Jeroen1971 Awesome! I'm glad to hear that your Versa 3 is back on track. 🙂
I'd like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
06-21-2021 10:22
06-21-2021 10:22
I am having the exact same issue and now mine won’t even give me a charging screen and the screen is completely black, but the button still buzzes when I press it. Sometimes it gives me a Fitbit logo and then goes black again but it has been charging for 4 hours or so with no progress. It has NEVER charged properly straight out of the box.
06-21-2021 11:58 - edited 01-08-2024 05:11
Hi there, @Khow430. Welcome to the Community Forums. Thanks for the details provided in your post. I understand where your concern is coming from.
Before considering other options, please check if the pins on the device or charging cable are dirty. For more information on how to do so, see Why isn't my Fitbit device's battery charging?
If the above doesn't work, as our last resort, I suggest performing a factory reset on your Versa 3.
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
03-21-2022 00:29
03-21-2022 00:29
I am now also having these exact same issues - have had my Versa 3 less than a year!! This is very disappointing - anyone able to help?? I've tried all the cleaning and plugging/unplugging as suggested.
Thanks~
03-21-2022 00:49
03-21-2022 00:49
HI @ChurchGirl68 - often reasons for not charging are dirt in the 4 contact holes on the watch or a faulty charge cable, see How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
03-21-2022 10:34 - edited 11-26-2023 16:20
Hi there, @ChurchGirl68. Welcome to the Community Forums. I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
