03-16-2022
16:17
20:17
03-16-2022
16:17
20:17
My versa 3 will not charge. I cleaned the device and charging cable with alcohol. I changed outlets, etc
hi @cv7754 - if you have had the watch a while it is important to clean the contact holes and check the charge cable state, they can be come faulty, see How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
Hello,
I tried using different different ports for the charging cable and cleaning the device, etc. I contacted Fitbit support and they are assisting me with the device. Thank you for your advice.
Regards,
Carol
