01-28-2024
23:29
05:36
01-28-2024
23:29
05:36
Why isn’t my VESA 3 not charging?
Hi there, @Stannermack. Welcome to the Fitbit Community Forums. It's sad to hear that your Versa 3 is not charging. I will do my best to help you with this.
Sometimes a Fitbit doesn’t seem to be charging when actually the issue is that it has become unresponsive (this can happen if the battery has been allowed to discharge completely). I'd recommend putting it on to charge on a charging wire and outlet known to be working. Leave it on the charger for a good two hours, even if it doesn’t seem to be charging.
When it has had two hours, try restarting your Versa 3. I would recommend trying this maybe twice in a row if a first try doesn’t work.
Best AnswerThe “restarting your Versa 3 link” isn’t working
Hi @tineturley88 @Stannermack - did you follow this link as the watch may still be fine How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
