10-02-2022
18:34
17:09
10-02-2022
18:34
17:09
My versa 3 won’t keep time. It is sometimes off by 5 minutes in 8-10 hours after syncing. It corrects after I sync but it should be able to keep more accurate time than it does.
10-03-2022 10:46 - edited 03-17-2024 05:57
Hi there, @MikeFinger. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
While reading your post, I was wondering if by any chance you used to have another Fitbit device prior the Versa 3? If any previous Fitbit devices is still linked to your phone's Bluetooth settings, that might be causing connectivity issues with your Versa 3 and the Fitbit app and somehow, syncing issues what would explain why the time won't stay synced.
With that said, try the steps below:
After trying the above, keep and eye on your Versa 3 to see if the issue persists.
Best Answer10-03-2022 10:46 - edited 03-17-2024 05:57
Best Answer10-03-2022 17:20 - edited 10-04-2022 18:05
@MarreFitbit I have no issue syncing my versa3 with my phone. My issue is with the Fitbit’s inability to keep time. It should not be 5 minutes off over the course of a day. I should not have to keep it synced with my phone to keep time.
Best Answer04-10-2023 17:27
04-10-2023 17:27
So my versa 3 still won’t keep time. The watch will be off by 5 minutes between syncs. Is there a reason why this happens?
Best Answer04-10-2023 20:13
04-10-2023 20:13
H> @MikeFinger - a watch that loses more than a few seconds per day is faulty.
I sync my watch once every 4 or 5 days only and the time is still accurate.
