04-07-2022
03:02
20:05
04-07-2022
03:02
20:05
My versa 3 up and quit working. I can't get it back on
Hi there, @Anita70. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
If you haven't done so yet, I'd recommend restarting your Versa 3. For instructions, see How do I restart my Fitbit device?
If the above doesn't work and your Versa 3 is showing just the Fitbit logo, please try the steps below:
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
Hope that helps.
