12-07-2021
15:58
20:43
12-07-2021
15:58
20:43
When I swipe up from my clock face, I only get a blank screen. I no longer get all my stats such as weather, steps, weight, sleep, heart rate etc.
Also when I press and hold the side button, I get the error message " Something went wrong, but it might work if you try it again." It never works.
12-08-2021 03:45 - edited 07-13-2024 03:00
Hi there, @esoper. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
Please restart your Versa 3 as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
12-08-2021 00:15
Hope that helps.
03-21-2022 18:50
03-21-2022 18:50
I’ve restarted mine 3 times
03-21-2022 20:21
03-21-2022 20:21
I'm having the same issue and restarting and changing faces isn't fixing it!!
03-21-2022 20:22
03-21-2022 20:22
I can't get to the settings on my watch. Only shows my clock face.
03-21-2022 21:12
03-21-2022 21:12
Hi @Jfblondii - try double tap of the screen and then swipe the face to the right to get to Quick Settings and disable always on, sleep and do no disturb icons and enable wrist wake (watch) icon.
03-22-2022 05:19
03-22-2022 05:19
03-22-2022
05:29
03:04
03-22-2022
05:29
03:04
@Jfblondii - did you double tap the screen or push the button? It could be stuck in Always On mode.
Check in the Fitbit App, click profile photo, device photo and make sure quick view is enabled. This will ensure your real watch face appears when you raise your arm.
Have you also restarted your watch?
03-22-2022 15:41
03-22-2022 15:41
I get exactly the same. I can swipe left and right, no problem, but when I swipe up to see my daily stats it’s just a black screen.
software update perhaps?
03-22-2022 19:31
03-22-2022 19:31
03-22-2022 19:34
03-22-2022 19:34
03-22-2022
19:58
03:00
03-22-2022
19:58
03:00
@Jfblondii , @justlogmein @Jo6672 , probably best to contact Fitbit support to help you with a factory reset to get back your widgets not showing, because if your watch is outside warranty there is always a risk the watch might not work afterwards.
If it is under warranty still, go to the watch Settings, About Versa 3 menu and select factory reset.
But make sure your watch is well charged first and do not touch your watch for several minutes to leave it time to complete the process.
Then press the button a second to restart it.
03-23-2022 01:30
03-23-2022 01:30
Hold button for 10 seconds and reset worked. Thank you!
03-23-2022 01:34
08-19-2022 15:33
08-19-2022 15:33
Exactly the same for me - happened after last firmware update - last week.
Changing clock face and restarting hasn't worked.
08-19-2022 15:46
08-19-2022 15:46
Have tried restarting again and if seems to have worked!!
09-12-2022 09:30
09-12-2022 09:30
my issue also... not fixing it. neither is changing the clock face.
21:48
03:03
09-12-2022
21:48
03:03
Hi @KristinaKP - if you have a new watch it can happen that it takes a few days for things to work, if a full Shutdown restart doesn't resolve it.
If it continues you can chat via the Fitbit App, click profile photo, Help & support, Contact Customer support.
Best Answer09-13-2022 15:22
09-13-2022 15:22
