09-09-2022
09:48
17:17
09-09-2022
09:48
17:17
Started using it on Monday,(birthday present),the battery died and I have put it on charge but nothing is happening,it will not switch on-screen is blank but I can hear soft vibrations every 4. Seconds,tried everything.
09-09-2022 13:24
09-09-2022 13:24
I've had mine for 7 months - it stopped last night at 5pm - it went black - won't restart, won't charge.
09-09-2022 14:43 - edited 08-30-2024 05:39
Hi there, @Nas4967 @MN.Jake. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 devices. I understand where your concerns are coming from.
In addition to the steps you've done so far, I suggest trying the following:
If you manage to bring your Versa 3 to life, but the battery keeps draining, may I know if you're using Snore Detection? If so, please note that the Snore Detection feature does impact your device’s battery, so we recommend charging your device to at least 40% before going to bed. For more information, see How can I use my Fitbit device to detect snoring and noise levels while I sleep?
However, I'd like to share with you that the battery life will depend on how frequent certain features are used in general. Because you're using an Always-On Display clock face, I'd recommend changing the clock face to another one made by Fitbit and monitor your it's behavior in the next day. Additionally, try turning off this setting by opening the Settings app on your watch > Display > Always-on display.
Hope this helps.
Best Answer09-11-2022 04:32
09-11-2022 04:32
09-11-2022 10:15
09-11-2022 10:15
Mine died last night, I last charged it Friday and usually it holds a charge for 3-4 days. It died after 24 hours and I plugged it in and it was burning hot but won’t turn on
Best Answer09-11-2022 10:15
09-11-2022 10:15
Mine is only 16 months old
Best Answer09-12-2022 08:42
09-12-2022 08:42
Same thing happened to mine after a year and a half. Black screen of death and won't charge on either one of my chargers.
Best Answer09-12-2022 21:51
09-12-2022 21:51
Hi all, if your watch hasn't suffered water damage and you checked cleaning, often the charge cable is faulty, see How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
09:25
09:05
09-14-2022
09:25
09:05
Mine stopped working yesterday while it was on the charger. When I got home I tried a different charger, and it's still not working. No vibrations, no faint image, just a dead screen.
Update: I contacted Fitbit support (via chat) and Fredy took me through several steps and somehow it turned on and started working again.
