07-07-2019 06:19
07-07-2019 06:19
My Versa that I’ve had since December 2018 has worked great until this past week when the battery goes from 100% to 0% in an hour or 2. I have cleaned the sensors, done the restart 4-5 times, left it on charger for 4+ hours and none of these things have helped. I am so disappointed as I have loved my Versa especially for exercise tracking as well as helping in my weight loss goals. Does anyone have any additional suggestions? Seems like 6 months is a short life span for an expensive piece of equipment!
07-07-2019 06:21
07-07-2019 06:21
I am having the same problem. I also notice that the face has started fading in a strange way after a few seconds. Is that happening to you?
Best Answer07-07-2019 07:23
07-07-2019 07:23
As of yesterday my battery starting draining extremely fast as well. I have had my versa for over a year without any problems until yesterday. I did the App update and did a restart twice but it has drained 20% in two hours
Best Answer07-07-2019 07:28
07-07-2019 07:28
Best Answer07-07-2019 07:29
07-07-2019 07:29
I haven’t noticed that that the face is draining just that all of the sudden it has gong from 100% to 0%. Possibly the face is draining but I’ve missed it because it is happening so quickly!! I’m just so frustrated!
Best Answer07-07-2019 07:57
07-07-2019 07:57
Best Answer07-07-2019 08:39
07-07-2019 08:39
It just turns black. I’ve had it off charger now for 2 hours and it’s down to 20% already! So frustrating!!!
Best Answer07-07-2019 08:47
07-07-2019 08:47
Best Answer07-07-2019 14:41
07-07-2019 14:41
Best Answer07-07-2019 15:05
07-07-2019 15:05
Best Answer07-07-2019 15:53
07-07-2019 15:53
Mine is also doing the same thing. I bought mine in June 2018. It started after I updated the app on my phone on Wednesday. The next day, I had it turned off before I went to bed and when I woke up the battery was on 0%. Since then the battery rapidly decreases like something is draining the power.
Best Answer07-07-2019 16:20 - edited 07-07-2019 16:28
Since you've had it less than a year, it should still be under warranty. So, contact Tech Support.
Here's what they had me do: 1. Plug the charging cradle into a different power source. If you usually use a wall charger, try a PC or laptop. If you usually charge from a PC, try a wall charger. They want to ensure you are charging from a good source (though if the charger isn't up to the job, why does the Versa indicate 100%? (They couldn't answer that.)) 2. If that doesn't help, they will have you do a test to see just how long the battery lasts. Charge to 100% and make note of the date/time you do so. Then just wear it until the battery dies completely. Make note of that date/time also. Sync the Versa often so they can look in their logs to see how quickly it is draining.
My replacement should be here Thursday. Meanwhile, I am charging a couple times per day...
07-07-2019 16:46
07-07-2019 16:46
Thank you for the advice. I bought it June 25th of last year. So, I am about two weeks out of the warranty.
Best Answer07-07-2019 16:56
07-07-2019 16:56
I am in the exact same boat. I have a fully charged Fitbit Versa and twice in the last week it has died on two 2-hour bike rides! I am using GPS, but nothing should drain that fast and it was not problem before!
Is there a battery replacement or is it time to dump it??
Best Answer07-07-2019 17:21
07-07-2019 17:21
I noticed the exact same thing. I have had mine since January of this year (so only 6 months as well) and it was consistently a 4-day charge. I changed NOTHING in my settings and all of a sudden, it needed charging every 24-30 hours. I contacted tech support and they had me do a battery drain test on and they are sending a replacement. I have seen other posts recently about this sudden change too. I think it is a software issue and not the actual fitbit itself but we will see. Just go through customer service and see if they can help. If enough people bring it to their attention hopefully they will act fast on it. Even if it is out of warranty, they will still have options for you.
07-07-2019 18:30
07-07-2019 18:30
Best Answer07-08-2019 17:20
07-08-2019 17:20
Best Answer07-08-2019 18:13
07-08-2019 18:13
I have been on hold for 25 minutes to try to get some help or action. No one is answering or helping. I am also lost without my Versa. So disappointed in the customer service. Am super frustrated with Fitbit. Don’t want to buy an Apple Watch, but it’s looking like I’ll be having to do so... Fitbit- you’d better start stepping up your game!!
Best Answer07-08-2019 18:16
07-08-2019 18:16
I’ve done all these things and also have tried contacting Customer Service and have yet to get a response. Have tried to call twice and was on hold for over 25+ minutes. Losing faith in Fitbit unfortunately
Best Answer07-08-2019 20:16
07-08-2019 20:16
They replied within 24 hours after I let them know i completed the test and my new Versa shipped out the next day.
