Versa Battery Life
So I got my FitBit Versa a week and a half ago and was so excited to have a FitBit again as I used to have an Alta HR before it went missing. I charged my Versa fully that night prior to messing with it. And I’ve noticed that my battery life is only getting me through a day and a half which is a drastic difference from the claimed 4 day span it’s supposed to have. I know that apps, features, and clock faces can alter the estimated battery life but I don’t have the auto wake feature on, I keep it on the lowest brightness setting, I don’t really use the apps on there and my clockface is the preselected factory one. The only things I really use are the HR feature and the notifications for text messages, and even then I keep my phone on do not disturb 85% of the day and don’t get many texts in the first place. I also do not have Bluetooth speakers or headphones hooked up to my Versa.
Is there a reason my Versa battery isn’t lasting as long as it should? Could it be faulty? Or does pretty much everyone have the same thing going on...
2 REPLIES 2
That definitely doesn't sound normal. I get roughly 4 days of battery life with notifications, all day sync, 24 hour HR, auto brightness and screen wake on. I also regularly track runs with little effect on the battery.
Hi, since your Versa is almost brand new, i would strongly advice you to contact Customer Support and ask for a battery test. Maybe it's indeed faulty. Regards kuzibri
