03-10-2019 01:35
03-10-2019 01:35
Hi there, I just bought the Versa, with the main intention of using it at the gym/when exercising. I set it all up and then went to use my Bluetooth headphones on my android phone, but it seems that I can't have my versa and my headphones paired to my phone using Bluetooth at the same time. Which means I cannot listen to music while I exercise, which is one of the main reasons I bought the versa?! I paired the headphones to the versa successfully but it has not made a difference. I have to disconnect my versa if I want to lmuse my headphones with my phone. Can you help?
03-10-2019 10:31
03-10-2019 10:31
If you paired your headphones to both the phone and the Versa there is likely a conflict. I have my Versa connected to my phone and my car's bluetooth also connected. I can stream music and still get notifications.
Best Answer03-10-2019 17:04
03-10-2019 17:04
