03-06-2019 18:51
03-06-2019 18:51
Can't sync my LG V40 with my Fitbit Versa, anyone know if they are compatible or what may be going on?
03-06-2019 19:39
03-06-2019 19:39
I am having the same issue and I have an LG Q7. However, it does sync on my Samsung tablet .I have a coworkers who also has the Versa and has problems with hers connecting to her Iphone.
I think I might return it since I barely bought it.
Best Answer03-06-2019 19:48
03-06-2019 19:48
Unfortunately I got mine a while back, hopefully Fitbit will have an system update soon that takes care of this issue... thanks!
Best Answer03-07-2019 00:14
03-07-2019 00:14
Unfortunately, both of those phones don't show on the list of supported devices at www.fitbit.com/devices
This could mean that they have been tested and shown to not work (or not work consistently) or it could just mean that they haven't yet been tested.
If you can't set it up at all then it's probably not going to work. If it has gotten through the setup but has stopped syncing then it's worth trying the usual troubleshooting steps:
Best Answer03-10-2019 17:08
03-10-2019 17:08
I was FINALLY able to sync my Versa on my LG Q7+
What finally worked for me to remove all devices. Then I created a new Fitbit account.
Unfortunately it never synced to my previous account so I lost all my badges. It has been 3 days since I created the new account and it has been working well.
