03-12-2020 15:31
03-12-2020 15:31
I realize I do not have GPS in my Versa Light but notice that when walking/running with friends who use their Apple watches my distance is off over .50 miles. My gender and height are set up. Do I have to bring my phone with me on my walks and runs for a more accurate distance. Today I was under almost .75 miles. What's the best way to get an accurate reading? Thanks.
Best Answer03-12-2020 16:16
03-12-2020 16:16
If you a re confident of the distance, adjust your stride length up to get the right distance.
Without GPS, distance = number of steps times stride length.
See Can I change my stride length in my Fitbit account?
Best Answer03-12-2020 16:27
03-12-2020 16:27
Best Answer03-12-2020 16:49
03-12-2020 16:49
Did you read the instructions at the bottom of the link I included?
Best Answer03-12-2020 17:22
03-12-2020 17:22
Best Answer03-12-2020 17:39
03-12-2020 17:39
The easiest way is if you have a known distance course, such as a track. Run a lap, or more, see what distance Fitbit gives and compare to actual distance and adjust accordingly. For instance if you know you ran a mile, but Fitbit says you ran .9 mile, then increase your stride length by multiplying by (1/.9).
If you know you are always shorter than people you run with, and you trust their distances, you could go with trial and error. Try increasing stride length a bit at a time until you get to same distance as running partners.
Best Answer03-12-2020 17:55
03-12-2020 17:55
