Hey guys,
I purchased my Versa Lite in August so it’s fairly new. I honestly think I’ve had a step count problem since I bought it, but today was my first time running to compare the distances. I jogged 3 miles on a treadmill and my Fitbit is showing I ran .81 miles. I understand there being a slight difference, but woah now!
I’ve changed my stride length about a million times. During my run today, my stride was set at 10 inches. Which is ridiculously low considering I wear a size 9.
Help! I really want to like my Fitbit and it’s great with my weight lifting and stairmaster, but I need accuracy on my daily steps and while jogging as well.
When you use the treadmill, do you keep your hands on the handle bars? Because then the reading doesn’t work.
On the other hand, when I’m riding a bike, sometimes I get extra steps.
I think it’s all in the movement of the wrist.
When you use the Versa outside while walking or running, use the GPS functionality.
it then can measure your stride length with should be albout 75 cm (30 inch).
Go on your phone to the Fitbit app
click on your picture top left
go to Advanced settings all at the bottom of the list
go to stride Length
Hey! I do not run with my hands on the bars. For the last mile, I overly pumped my arms while running and it didn’t make a difference.
I’ve tried the stride length on the default setting, on my actual stride length and a super low stride length. Still no difference. Stride length simply isn’t making a difference.
