11-25-2020 12:28
11-25-2020 12:28
My watch (Fitbit Versa Lite Smartwatch) was working perfectly but out of a sudden it went bank... I kept on charging it .. it shows green lightning n the back .
I would like to have a replacement please.
I sent Fitbit long time ago and till now they didnt reply back to me!!
Best Answer11-25-2020 13:46
11-25-2020 13:46
Hi @Haya123 when you sent your Fitbit back, did you have a RMA (Return merchandise authorization) and a case number? If you sent it without these, it might take much longer.
Best Answer11-25-2020 17:14
11-25-2020 17:14
No didnt
Best Answer11-25-2020 17:51
11-25-2020 17:51
@Haya123 you returned your Fitbit to them without getting prior approval? Fitbit customer support generally helps a person to work to fix the device before authorizing a return, if it's under warranty.
Best Answer11-26-2020 14:39
11-26-2020 14:39
I sent the help desk not the watch!
I didnt send it but I need to have a replacement... and till now no one replied back to me.. what should I do
Best Answer11-26-2020 16:21
11-26-2020 16:21
Fitbit customer support is doing their best, but right now be prepared for longer wait times. Please be patient. Support is limited by the number of representatives available at a given time and the hours of operation. Chat lines are open when they have live help.
USA: call (877) 623-4997
UK: call 0800 069 8505
INDIA: call 000 800 050 1057
IRELAND: call 01 691 7502 (country prefix: +353)
Other contact options:
USA: click
Canada: click for options
