08-06-2020
10:36
12:01
08-06-2020
10:36
12:01
My Fitbit became unresponsive yesterday, then turned back on. The time was off. Did a restart and updated. The left button isn’t working. Shut it down from my watch. Plugged it in to turn it back on. The left button still don’t work, then the entire watch becomes unresponsive. This is less than a year old.
Hi there @MomOfGroms, welcome to the Community Forums. Thanks for the details provided in your post about your Versa Lite's recent behavior and for your time and efforts in troubleshoot your watch prior to posting here. I'll be glad to help you.
In order for me to better assist you with this, please confirm that you've followed the steps below as described below:
If the suggestions don't work and your watch doesn't vibrate when you connect it to the charger, it may not be having a good connection with the charger and therefore, it won't properly charge. Said that, I recommend doing the following:
If the above steps don't work, at this point I recommend doing a factory reset (before doing so, make sure to remove your watch from your Fitbit account):
Take in consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Hi there @MomOfGroms, thanks for getting back. In regards to your inquiry, note that it's the only button on your Versa Lite the one you need to hold.
About changing the clock face, please try changing it as suggested and see if your screen and button response again.
If that is not the case, please let me know so I can further assist you with this matter.
Hi there @MomOfGroms, I appreciate you had followed the tips and recommendations provided above. Since this sounds a bit more serious, I've created a support case on your behalf - you should soon receive an email from Customer Support at the email you used to register with the Community forums. Note that we may take a bit long to get back to you since due to recent events affecting our operations, support options are limited and wait times are longer than usual. If you have any questions, don't hesitate to let me know. 😉
Hi @MomOfGroms, you're very welcome! Please stay tuned to your inbox, our team will definitely do their best to help you out. 😉
