Versa Lite screen not responding
ANSWERED
Hi there,
My 1 week old Versa Lite screen is suddenly not responding to touch . Any troubleshooting tips?
1 BEST ANSWER
Accepted Solutions
Yes, that should restart it. No luck with that? I would suggest getting in touch with Fitbit Support directly then. That's about all you can do on your end without access to the screen.
MakMak | Community Council
3 REPLIES 3
Hi, @EAtkinson! Have you tried restarting it?
I held down on the button until the fitbit symbol came on then released it. I believe this restarted it? Most info I found when researching was for the Versa (and the 3 buttons), not the Versa Lite.
Sent from my iPhone
