03-18-2020 09:06 - last edited on 09-03-2020 06:26 by MarreFitbit
Lately my screen on my versa lite seems to be dim, anybody else or any suggestions. It’s less than a year old
03-18-2020 12:20
03-18-2020 12:20
Have you checked the 'Brightness' setting in the 'Settings' app?
03-18-2020 12:20
03-18-2020 12:20
03-18-2020 12:52
03-18-2020 12:52
03-18-2020 12:52
05-03-2020 15:23
05-03-2020 15:23
my versa goes dim when I am outside in bright sun. Can't read anything, go to darkened area and go to settings, brightness is on DIM, can't activate or reset it no matter how I tap screen or try right side button next to brightness setting. Finally just kept scrolling around and found a SUN icon and tapped it and set to BRIGHT.
Happy now.
05-03-2020 15:24
05-03-2020 15:24
Brightness setting is dim tapping does not bring it up or any way to change it from DIM
09-02-2020 08:46
09-02-2020 08:46
How do you do that, if you can't see it?
09-02-2020 15:59
09-02-2020 15:59
@RobII - take your Versa into a dark room. That will help make it more visible.
09-04-2020 11:11
09-04-2020 11:11
Carol, was supposed to be Charge 3 forum. Sorry, but thanks anyway!
