08-17-2020
12:56
13:40
08-17-2020
12:56
13:40
My versa lite has been working fine and today it advised it required an update which i tried to complete and it kept saying it couldnt connect
It has now gone off and wont come back on, it wont even charge!!!!
This is the second device i have had since receiving this as a gift for Xmas 2019 i didnt expect a device that costs in excess of £150 to break twice!!!!
Please ensure this issue is resolved asap
08-18-2020 13:43 - edited 09-24-2024 16:15
Hi there @RebeccaF1981, welcome to the Community Forums. Thanks for the details shared in your post about your Versa Lite's screen behavior. I understand where your concern is coming from, I'll be glad to assist you.
If you haven't done so yet, I'd suggest trying the steps below:
If the suggestions don't work and your watch doesn't vibrate when you connect it to the charger, it may not be having a good connection with it so your watch may haven't had the chance to get fully charged. Therefore, it won't turn on. So, please try these recommendations:
Give this a go and let me know how it goes.
08-19-2020 04:17
08-19-2020 04:17
I have tried both of these and neither have worked
08-19-2020 05:45
08-19-2020 05:45
I have mine only since june mine went blank too did you get yours workinh
08-20-2020 05:05
08-20-2020 05:05
No its completely dead
08-20-2020 07:59 - edited 09-24-2024 16:15
Hi there @RebeccaF1981, thanks for getting back and for the update. I appreciate you had followed the tips and recommendations provided above. Since this sounds a bit more serious, I've created a support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums. Note that we may take a bit long to get back to you since due to recent events affecting our operations, support options are limited and wait times are longer than usual. If you have any questions, don't hesitate to let me know.
Hey @Adriennedoyle, thanks for stopping by and for letting me know that your Versa Lite's screen is also blank. If you haven't done so yet, please try the tips and recommendations I shared here.
Give this a go and let me know the outcome.
