12-08-2020
08:39
12:31
12-08-2020
08:39
12:31
My versa lite is less than a year old but has suddenly stopped working. I’ve noticed this is a common problem on here but don’t see any of the issues being solved ?
Hi there @Rachelgrace1, welcome on board.
So we can offer the assistance you need, would you mind responding to @Rich_Laue's question?
While we wait for your response, if you're experiencing any of the following issues and you've checked your settings, restart your device:
To restart your Versa Lite, please:
Looking forward to your response.
Best Answerit’ won’t turn on . I’ve tried resetting it and it’s not the charger as my daughters Fitbit chargers fine .
Hello there @Rachelgrace1, thanks for the update and for the steps you tried.
Did you feel any sort of vibration on your Versa Lite during the restart process? If you didn't, please try the steps below:
If the above steps don't work, at this point I recommend doing a factory reset (before doing so, make sure to remove your watch from your Fitbit account):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
Best AnswerTried all of that but still nothing ! It’s just dead ! No vibration
Hi @Rachelgrace1, I appreciate you had followed the tips and recommendations provided above. Since this sounds a bit more serious, I've created a support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums. Note that we may take a bit long to get back to you since due to recent events affecting our operations, support options are limited and wait times are longer than usual.
