08-02-2020
18:07
05:45
08-02-2020
18:07
05:45
I have had my fit bit for over a year and I wanted to factory reset it because I wasn’t getting correct information from it. When I did that it would not let me start up my Fitbit. It keeps saying I have updates and all I’ve been doing is updating it. What do i do now? When I try to update it, it won’t let me and it’s frustrating.
08-03-2020 05:52 - edited 06-12-2024 05:13
Hi there @Sabryna, welcome to the Community Forums. I'm sorry to hear about the recent issues you've been having with your Versa Lite. Thanks for the details provided in your post and for your efforts in trying to fix the issues prior to posting here. Nice way to go!
Please note that this kind of trouble usually happens when you performed a factory reset without before unpairing the device. Usually you should unpair your smartwatch from the Fitbit account and phone's Bluetooth settings and perform the factory reset. In order for me to better assist you with this, please confirm that you've followed the steps below:
If you can't get started with your Versa, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
In regards to the version installed on your Versa note that your watch must be updated to the latest Fitbit OS 4.1.3 (32.70.8.0) and the Fitbit app on your phone to 3.26.1. May I know what is the version currently installed on your watch? You can find by going on your Versa, in the Settings app > About or Device Info.
Make sure to check them out and let me know if the issue persists. If such is the case, my best recommendation will be to get in touch directly with our Technical Customer Support department here. I would also contact them on your behalf if necessary, just mention me and I'll move forward with the request.
I'm looking forward to your response, keep me posted.
09-03-2020 18:17
09-03-2020 18:17
I factory reset my Versa lite fit bit and lost all my apps and info. I do not understand how to fix this mess. Help!!!
