09-02-2020 10:34
09-02-2020 10:34
Hi @LRevelo
I'm sorry you are having an issue with syncing. Have you trying doing a restart on your Versa? If you haven't I'd suggest that next and also make sure you don't have any updates pending on your mobile and your Fitbit. If a restart doesn't work, then a factory reset would be the next thing to try. You can find instruction HERE. I hope that helps.
09-02-2020 10:46
09-02-2020 10:46
This has been a problem for me for two days, since I charged my fitbit on Sunday Aug. 30th. My fitbit is also stuck at 1 1/2 days behind, I've shut down my fitbit twice, changed clock faces and added different notifications to try getting it to "catch up".
09-02-2020 10:54
09-02-2020 10:54
09-02-2020 10:55
09-02-2020 10:55
Hi @Taylormaee
I'm sorry to hear you having an issue. It sounds like a factory reset is the next step for you. The instruction can be found HERE.
09-02-2020 10:58
09-02-2020 10:58
09-02-2020 11:00
09-02-2020 11:04
09-02-2020 11:04
Factory reset doesn't mean losing your data. It just means you need to set up your device again. Just make sure to sync before you do the reset and your data will saved to your profile and can be viewed on the mobile app in the Today screen, just like it always is.
09-02-2020 16:30
09-02-2020 16:30
My Versa 2 won't sync either after charge. It is stuck on wrong time and won't sync. I've tried everything except factory reset .I think fitbit does this on purpose do we buy new fitbits.
09-02-2020 17:42
09-02-2020 17:42
09-03-2020 01:20
09-03-2020 01:20
09-03-2020 01:37
09-03-2020 01:37
That’s funny - do a factory reset to get sync working but do a sync first -HaHa
09-03-2020 06:25
09-03-2020 06:25
Hi @SunsetRunner
I have asked a Fitbit Moderator to jump in and help resolve this problem.
Thanks for your patience.
09-03-2020 17:50 - edited 09-03-2020 17:51
Hi everyone, nice to see you all here! Thank you for your efforts.
Just to clarify, the All day Sync option that was on the Android Fitbit app, has been removed since a few app updates ago.
@MarciM , thank you for your help, we really appreciate it.
@SunsetRunner , thank you for the information about your devices and apps. Please go to the settings of your A3. Settings>Apps>Fitbit App. Clear the Cache of the Fitbit app.
Then follow the instructions described below.
To everyone else, could you please confirm the mobile device you are using as well as the Operation System version ? So that I can provide more detailed instructions for each one of you.
In the meantime please follow these steps. Some of them you already might have performed, but the order is very important.
Please check that the energy saving mode and the do not disturb option (mute) are switched off on the mobile phone.
Also make sure that no other Bluetooth device is connected to the mobile phone or nearby. (Headphones, keyboards, etc.)
- Please verify that you all have the latest app update installed.
- For those using Android: please clear the cache of the app as described above to geordie613.
For those using iOS. Turn the mobile device off and on again.
- Restart your watch How do I restart my Fitbit device?
- On the mobile device go to the bluetooth menu and unpair/delete/remove all the connections between the watch and the mobile device.
- Restart the phone (off/on)
- Open the Fitbit app and try to setup the watch as a new device.
Let me know how it goes.
