09-28-2021
06:51
07:48
09-28-2021
06:51
07:48
I have just purchased Fitbit Versa Lite and on my first charge the watch does not respond and displaying black screen. Eventually it shows a fitbit logo, but shortly after it goes back to black again. This cycle goes on and on even after keeping it connected to the charging cable for 24h. It just turns on whenever it wants. What should I do?? I have not even got the chance to use it as it was still fresh out of the box.
Hi there, @Dkkhouw. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa Lite before reaching out.
In addition to the steps you've done so far, please see Why isn't my Fitbit device's battery charging?
As for the Fitbit Logo, while you have your Versa Lite connected to the charger, please try the steps below:
If you can't get started with your Versa Lite, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
Hope that helps.
Hi @Dkkhouw in case you need it, here is the Versa Lite user manual - click to go there. Might be a good idea not to leave it on the charger for 24 hours. They usually don't need more than a few hours to charge from a low battery.
Thank you Marre for the response.
At this moment there's little that I can do with my Fitbit Versa Lite as it is fresh out of the box. I have not paired it with my account via bluetooth as my device is unable to detect the presence of the watch.
I have tried cleaning the back of the watch as recommended with a cotton swab and alcohol, and did the same to the charging port. I also tried restarting it using the recommended 10 second hold, but both to no avail.
@Dkkhouw I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
