01-06-2020
19:12
05:14
01-06-2020
19:12
05:14
Hi, I couldn’t find any threads about the Versa Lite going dead. It was at 92% battery life this morning, and tracked my run until about 3 hrs ago. Now the screen is blank, nothing flashes on the back, and putting it on the charger did nothing.
I tried resetting by holding down the button for at least 10 seconds several times, but no love yet. I only use it with my iPhone, no computer.
i just got this for Christmas, and was really starting to enjoy it! I did a FW update, but that was when I first took it out of the book.
Please advise soonest. Unhappy. 😞
Best AnswerHi @Ahrjones I am not surprised you are unhappy! I have flagg3d a moderator to come and help you.
Helen | Western Australia
@Ahrjones Welcome to the Fitbit Community! I hope you're doing well! Sorry for the delay in my reply.
Let me help you with your unresponsive Versa lite and thank you for troubleshooting this issue. Since you have already reached out to our Support team please work with them to find a solution. They are able to view your Versa lite's data and determine what the issue may be.
@NellyG thank you for your help in this thread.
Let me know how it goes.
Best AnswerMy replacement Versa Lite has already shipped. Sad I have to wait but I hope this one is from a different lot, and more robust.
Best AnswerI am on my second Versa Lite in two months. I ordered the first one end of November and it died on the very last day I could get it replaced. The new one has died two days AFTER the replacement/refund period. Exactly the same issue - suddenly totally dead, black screen, won't charge, nothing at all. Amazon has said they will discuss it with the manufacturer (Fitbit I assume) when I get home from holiday. I really like my Versa Lite but I am very loath to get yet another one if this just keeps happening. Does anyone have any advice? Is it just Versa Lite this happens with or all Fitbits? Has anyone tried an Apple Watch? Thanks in advance!
Best AnswerI've been a Fitbit user for years. Have only had issues with my Fitbit versa lite. I had the one for years and then an alta and alta hr. No problems. I'm on my 2nd versa lite within 1 year. Horrible
Best AnswerI purchased my Versa Lite through QVC on 10/20/19. Use it all the time. During the night it DIED. On my phone it shows moderately charged. Went to bed about 9:00, it recorded my heartbeat until about midnight. This morning, absolutely nothing, held the 'back' button, the only button on it, nothing! Tried to charge it, nothing! What can I do?
05:08
05:13
06-16-2020
05:08
05:13
I"m sorry. I can't actually remember how I got hold of support (but when I
did they were good!) They have a "no-reply" address when they email.
Moderator Edit: Personal info removed
Hi @Khaskhist, welcome to the Community Forums. Thanks for the details provided about your watch's behavior. I'll be glad to help you.
The battery on your watch may not be charging properly and therefore does not turn on or even it's causing a battery drain. I recommend that you follow these steps:
Please make sure to check them out and let me know if the issue persists. If such is the case, my best recommendation will be to get in touch directly with our Technical Customer Support department here. Also, I can contact them for you if necessary, just mention me and I'll move forward with the request.
Though, if the steps provided in the post don't work but you have either the Versa 2 or Versa Lite, I'd recommend performing a Factory Reset as follows (note that when doing a factory reset you'll need to reinstall any apps on your device after, and if you couldn’t sync your device, then any data on the Fitbit device will be lost from the last time sync until now):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Thanks for helping out @madharper!
I'll be around, keep me posted.
Hi @Brittney3, welcome to the Community Forums. If you're having issue with your watch's display, please take a look at my last post and try following the troubleshooting steps.
In regards to your inquiry about the chat support, click here where you can see all our support channels. Also, I can contact them for you if necessary (once you've followed all the recommendations), just mention me and I'll move forward with the request.
I'll be around.
05:59
06:38
06-16-2020
05:59
06:38
Thanks for that. Pretty interesting about cleaning. However mine was
TOTALLY dead. ie this bit ~ "Hold the back button for about 8 seconds.
When the Fitbit logo disappears" was totally irrelevant for me as I didn't
have a logo showing. It was just a black screen which did not respond to
anything at all.
