12-13-2019 21:43
12-13-2019 21:43
Have been using Charge HR for several years and sync to my computer with hardly ever a problem.
Don't have a smart phone or android.
Question: Can the Versa Lite sync to my computer?
Best Answer12-14-2019 00:20
12-14-2019 00:20
Hi
It's possible to sync the tracker to a Windows 10 computer over bluetooth with the Fitbit App for Windows 10 which can be downloaded from the Microsoft Store for free.
It's also possible to sync using a iPad with the Fitbit app installed on the device when having a Mac.
Hope it helps,
When having any questions feel free to ask.
Best Answer12-14-2019 11:50
12-14-2019 11:50
Best Answer12-15-2019 01:26
12-15-2019 01:26
Windows 7 isn't supported anymore.
From @YvanM 's reply in the thread Re: Can I setup up a FitBit on Windows 7 Pro?
01-14-2018 08:24
Good day, even with a dongle it does not work. I recently chats with a rep and here is what he told me. 'Mauricio: I am asking you this since Windows 7 is not longer supported by the Fitbit app. As you shared with me, the Fitbit app works only with Windows 8.1, and Windows 10.Me: So What can I do? Return the fitbit and buy Garmin?Mauricio: Thank you fo rthis Feedback. Ivan, I personally understand you'd like to set up with a Windows 7 computer, however, to be able to have all the features from the tracker working at a 100%, and to see the dashboard with updated graphs, your operating system needs to be updated as well.
