04-13-2019
05:15
08:26
AlejandraFitbit
04-13-2019
05:15
08:26
AlejandraFitbit
Hi,
I just bought my Fitbit yesterday. Initial pairing went smooth with my iPhone X but soon after I got incessant messages saying that the app was having trouble connecting to my watch. Then I realized that the Bluetooth connection was dropping every 5 seconds.
Now I can’t get it to sync at all it says “connected” then starts to sync, and then says “looking” and quits the sync. I’m currently restoring it to factory and reinstalling, which is what worked when I first set it up, but I cannot do this every day! Please tell me someone has a fix for this.
Edit: I have also tried everything that Fitbit help article suggests, I’ve unpaired every other Bluetooth device I have.
08:25
09:25
04-14-2019
08:25
09:25
A warm welcome to the Community @Mmartin97.
Thanks for troubleshooting this syncing issue by yourself. I recommend taking a look at the help article Why won't my Fitbit device sync? and follow the instructions provided there.
If this process doesn't work, from the Fitbit app tap the Versa Lite icon and provide me with a screenshot of what you are seeing.
I hope to hear from you soon.
Best Answer10-04-2019 13:55
10-04-2019 13:55
I had the same issue mentioned by someone earlier. I hooked up my Versa Lite with my iPhoneXr. It worked great but the next day stopped syncing consistently. I tried everything the manual said, undid and redid the bluetooth collection, shut down the app and the phone. Even called customer service (where the person cut off so no help there). This is super frustrating for a new purchase. I see that I am not alone in the syncing issue - has there been any progress?
12-17-2019 17:16
12-17-2019 17:16
What I had to do is to shut down my iPhone 8 and after that, it worked like a charm and I haven't had another problem since.
Best Answer12-29-2019 09:21
12-29-2019 09:21
I received. Fitbit versa lite as a Christmas gift and it won’t sync with my Samsung J5 can I take it back to the shop and get a refund ?.
Best Answer12-30-2019 17:11
12-30-2019 17:11
It's my husbands old HTC. It finally sinq, but will not download new update.
Best Answer01-11-2020 08:23
01-11-2020 08:23
Did you ever get it to sync? I have a samsung s9 phone and in dec 2019 i bought a new fitbit Versa Lite. It paired up w the fitbit app on my phone but now it wont sync. I restarted my phone last week and it worked again. Two days ago i went to check my app and saw that it wasnt syncing again. This is so frustrating.
01-11-2020 08:32
01-11-2020 08:32
I returned it to shop and received a refund I have now bought a Garmin vivomove and it's fantastic 👍🏼
Best Answer03-02-2020 08:26
03-02-2020 08:26
I had a not so fancy stylo 5 would not sync called customer service and gave my linked fit bit email and they fixed works perfect and o get texts on my vera lite
Best Answer03-03-2020 18:11
03-03-2020 18:11
Best Answer04-17-2020 07:34
04-17-2020 07:34
I cannot get my Versa Lite updated! Very frustrating, I have spent days trying to update my tracker. I have reset tracker, removed and tried to add new device, turned my bluetooth off and back on, used my laptop and even tried a different wifi. I purchased it in November. Help!
04-21-2020 11:37 - edited 04-24-2020 05:42
I am having the same problem. The versa lite won’t connect to my phones Bluetooth and therefore, it’s not syncing my data. I tried EVERYTHING x 3 on the help forums and still nothing. I contacted FitBit and she really didn’t help much. She said that she escalated my issue to IT / the engineers and they are working to get it fixed, when I asked what the time frame would be, she said she doesn’t know. I bought this versa lite last year in July, before I had a Versa but the screen popped off out of nowhere 1 month after my warranty was over. I went to 2 versas In less than 2 years. Very upset w this. Ridiculous.
Best Answer04-21-2020 12:16
04-21-2020 12:16
Best Answer04-21-2020 12:36 - edited 04-24-2020 05:51
I did that and it worked , but only until I disconnected it from my computer 😓...
Best Answer04-21-2020 13:44
04-21-2020 13:44
Best Answer04-21-2020 14:44
04-21-2020 14:44
04-22-2020 10:00
04-22-2020 10:00
Similar issue. The device will sync maybe one out of three times. But I can't change clock faces. Keeps saying Syncing Apps but nothing happens.
Tried turning Versa Lite on and off
Tried turning bluetooth on and off
Tried deleting the device from the app
Tried deleting the app.
Nothing.
Best Answer05-20-2020 02:07
05-20-2020 02:07
Same issue here connecting to a Samsung Galaxy S7, but now not even the date and time are correct because i did not charge it for a few days.
Please help, i am a student and definetly don't have money for a new sports watch!
Best Answer06-04-2020 08:53
06-04-2020 08:53
It seems that this issue is an ongoing problem. I have noticed over the past couple of days that the time is at least a few minutes behind, sometimes up to a half hour. I have made sure that my phone, app, and device is up to date. I have reset both my phone and device several times. When the app will actually let me sync, the time will update for a while but then will lag. I have tried to turn on auto-sync, but the option is not available. I am only able to sync now. Please let me know how to correct this, as it is very frustrating and makes the watch pointless.
Best Answer06-04-2020 09:14
06-04-2020 09:14
