09-26-2022
05:24
08:49
09-26-2022
05:24
08:49
My versa 2 is not showing the correct time it is losing minutes any suggestions on how to fix that
09-27-2022 08:50
09-27-2022 08:50
Hi there, @Deboone. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa Lite. @NellyG Thanks for your help!
Please keep in mind that the time on your watch should be corrected when you sync it. If you're experiencing difficulties with syncing, please try our complete troubleshooting instructions in this help article: Why won't my Fitbit device sync?
Nevertheless, note that the time on your Fitbit Versa Lite may be wrong after you travel to a different time zone or when clocks change for Daylight Savings. If you changed time zones and the time on your Versa Lite is still incorrect after syncing, make sure the time zone setting is correct. For more information, see How do I fix the time on my Fitbit device?
Hope that helps.
Best Answer09-26-2022 06:29
09-26-2022 06:29
Hi @Deboone Have you tried Restarting the watch? Also make sure it is syncing with your phone. If it is not syncing try THIS Help Article on syncing problems.
Helen | Western Australia
Best Answer09-27-2022 08:50
09-27-2022 08:50
Hope that helps.
