03-04-2021 02:37 - last edited on 03-05-2021 14:14 by LiliyaFitbit
My versa lite won’t sync to my phone. I’ve tried all the troubleshooting steps and turned Bluetooth on and off, deleted the app and Re downloaded, Turned tracker on and off several times. I even reset my tracker and now I can’t get it to pair with my iphone. I just can’t get the Fitbit device to connect atall
Best Answer03-05-2021 15:02
03-05-2021 15:02
Hi @Hattieb4, it's nice to see you again in our Community Forums.
Thanks for the details shared in your post and for already trying to resolve the issue. If you're unable to pair your watch to your Fitbit account, please follow our complete troubleshooting tips at Why can't I set up my Fitbit device? For syncing difficulty, please check here.
Hope this helps!
Best Answer03-08-2021 02:37
03-08-2021 02:37
I have tried these tips, my Fitbit will very occasionally sync, once every other day. I go through disconnecting Bluetooth, restarting devices and phone and even deleting and re downloading the app. This doesn’t work every time and it takes a really long time. Anymore advice?
Best Answer03-08-2021 17:33
03-08-2021 17:33
Thank you for your reply, @Hattieb4.
I appreciate your efforts and the additional details. I understand that you can sync your device occasionally and recommend after setting up your watch to not remove it from your Fitbit account. Please also let the Fitbit app run in the background to check if the watch will continue syncing. For more information about syncing your watch, see How do Fitbit devices sync their data?
Hope this gets you back on track.
Best Answer03-08-2021 18:13
03-08-2021 18:13
My Fitbit device has now stopped working. I deleted the app and upon reinstalling, said there was an update for the tracker. The update kept stalling and displaying a red ‘x’. Occasionally the device would display a green tick but then the app would say it needed to update. This would repeat and now the device has turned off and stopped working all together.
03-08-2021 19:24
03-08-2021 19:24
Thank you for the update, @Hattieb4.
I am sorry to hear you continue experiencing difficulties with your watch, thank you for your efforts and the additional details. The best way to get help for this problem is to chat with our Support team online or give them a call. They will evaluate your device's behavior and help you with this matter. Click here to get connected.
See you around.
