08-28-2021
07:20
08:56
08-28-2021
07:20
08:56
Hola, I have a problem;
My fitbit doesn't turn on and doesn't respond when I press the power button to restart. After a few minutes of pressing the button, the fitbit logo appears and soon after it goes dark again.
When I connect the Fitbit Versa in windows 11 with the USB cable, the computer recognizes the device as "USB serial (Com 6)". I believe it may be a software problem, how can I solve it?.
Best Answer08-28-2021 08:57 - edited 08-19-2023 07:28
Hi there, @Danimar_Costa. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa Lite before reaching out.
I'd suggest trying the following steps:
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove your Versa 2 from your phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
