02-28-2021
01:26
13:24
RicardoFitbit
02-28-2021
01:26
13:24
RicardoFitbit
Hi my versa has just completely stopped and wont charge... just died.
Ir was purchased 13 months ago.
Help please
Best Answer02-28-2021 04:42
02-28-2021 04:42
Best to check what is wrong
To see what's happening with the charge
Connect the charge cable to the watch and plug it into a PC USB port
The PC should announce a connected device with a sound, it means its connected and charging [if there is no sound, either the volume on the PC is low, or off, or the watch is not properly connected to the charger or has a fault]
if PC then announces a disconnected device with another sound, it means the watch battery is either flat or the watch is dead
anyway wait 10 minutes [for battery to get to 5%] if the watch or battery is not dead it will announce device connected again [the watch may also wake up]
if after an hour there is nothing on the watch face try starting it by pressing a button for a few seconds and waiting for the logo to appear or restarting with the buttons
if nothing comes on the screen, either there is a screen or button fault or the watch is dead - but wait
Check the button start procedure, to make that the button clicks |
Best Answer02-28-2021 05:11
02-28-2021 05:11
Mine died last night but it was charged at 75%. I can't tell if it charged. The screen is black. And it won't sync on the app. I too got mine exactly 12 months ago. It was for my birthday last year and today is my birthday.
02-28-2021
05:17
13:01
02-28-2021
05:17
13:01
02-28-2021 21:23
02-28-2021 21:23
Mine died on On 27, battery suddenly dropped to 0% the night before was 70% more. Tried clean the charger pin, charged for serval hours, passed buttons for factory setting still nothing on screen.
Best Answer02-28-2021 22:39
02-28-2021 22:39
Probably best to contact Fitbit Support directly in case they may be able to help you.
