10-02-2019 22:18
10-02-2019 22:18
Ideal position my watch is showing calorie burn , example, whole night i keep my watch on table & morning i saw it;s 400-500+ calories burn, Not sure it;s product fault but when i checked with customer support , per them , watch will calculate based on your profile which you set, so it will show calorie burn ..
But my question is , without doing anything how watch is showing 400-500 calorie burn? It;s product fault ? or i am only facing this issue?
How i calculate actual calorie burn in a day ? Please help me to understand.
Reg/Vishal
10-02-2019 22:31 - edited 10-02-2019 22:32
Welcome to the forums!
The calories burned are BMR calories. Your fitbit also calculates calories burned for your BMR. You burn calories just by being alive! Even Sleeping. Fitbit includes these burned calories in it's calorie calculations, so even if you did not wear the fitbit, you'll still burn these calories.
See this thread as well by @ColinM39
To Learn more about BMR
Wendy | CA | Moto G6 Android
10-02-2019 22:41
10-02-2019 22:41
Thanks for your swift response & explanation...
I have one question .. How I can calculate actual Calorie burn for the day ? If i am not doing anything but my watch is still calculating based on BMR..
but my question is, how i can see my actual calorie burn in a day ? where I will get my actual numbers?
10-02-2019 23:17
10-02-2019 23:17
Your actual burned calories include the BMR. In other words Fitbit shows you total calories as BMR + active calories (those derived from movements other than BMR).
If you want to know your active calories only (not sure why you should want) then it is not possible in Fitbit environment.
