06-02-2020 08:29 - edited 06-02-2020 08:30
Hi,
I am locked out of my versa which says to unlock using the phone. However, Versa is unable to pair/sync with the app on my Iphone.
Tried to reset/restart versa, Restart my iphone, still no luck.
I delinked versa from my profile and tried to link it back which fails to connect now.
Appreciate if someone can please help out.
06-02-2020 10:23
06-02-2020 10:23
Hi @Vijusher when you are requested to unlock with a phone. This is a 30 second task.
Open the Fitbit app, go to your trackers settings, device lock and set new pin.
Removing will make problems worth, and a restart will only restart.
You now have to do a factory reset.
For the Versa
Fitbit OS hardware reset.
On the watch, hold all three buttons for about twelve seconds. This will trigger the 2-button hardware restart after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, whilst continuing to hold the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
06-02-2020 10:23
06-02-2020 10:23
For the Versa
08-07-2020 20:21
08-07-2020 20:21
I have tried this so many times and still cant get a factory reset? it continues to still be locked
08-07-2020 23:00
08-07-2020 23:00
@Pratty101 is your tracker still connected to your Fitbit account?
If so it will take less than 30 seconds to unlock the tracker.
