Hi, how old's your Versa? battery life reduces the older the Versa gets.
check to see if the watch faces your using 'runs in the background' as if it is it will be running all the time even with the screen off.
The same goes for any apps you've got, check to see if any of those are running in the background.
Another idea is to uninstall all of the apps you can and delete all watch faces. If the battery life is significantly better try adding faces/apps one by one until you find the culprit.
Also, are you using 'real-time' heart rate monitoring? try disabling that then re-enable it after you've checked whether the battery life is better.
Are you using sleep monitoring, this can drastically reduce battery life.
Finally, you could try doing a Factory Reset, this often solves stubborn and weird problems.
Hope this helps
Best AnswerAre you playing music at the same time? After the latest software update I can't play music from my Versa without killing the battery. I just got back from the gym and after tracking exercise for an hour and wearing it for 3 hours I'm still at 94%. Two days ago I played music and it went from 100% to 38% in two hours.
