Hiya,
From today my Fitbit versa wont swipe on the screen. This includes left, right and up and down.
I have seen on other forums this has happened several people.
I have reset several times using the three buttons , I then gave up and set it back to factory settings and completely reinstalled the watch to the app which didn't make any difference so I then tried restart again several times and still no joy. I had the bit emoji clock face and removed it too so I am back to a standard Fitbit Face.
Did anybody try anything else that had actually worked? I am pulling my hair out to fix it as even getting to the settings on the actual watch is enough to make me want to throw it at the wall.
TIA
Hannah
Hi, does it work now going back to a Fitbit Clock Face? If not, restart your Versa 4-6 times in a row by pressing and holding the left and lower right buttons untill you see after each restart the Fitbit logo and release the buttons. I always advice to stay away form the Bitmoji Clock Face, cause it not only gives a lot of problems but also drains your battery like hell.
@SunsetRunner It's great to see you in our Fitbit Community! I'm happy to assist you with your Fitbit Versa since the screen is sensitive.
I'd just like to follow up and would like to know if the issue persists or if it got resolved after following the great troubleshooting steps that shared @SunsetRunner.
If you found his post helpful, please accept it as a solution so other users that experience the same issue can find it easier.
Looking forward to your response! ![]()
Hiya,
No the steps and advice previously given hasn't helped me any and the screen still has major issues.
The resetting of the clock face hasn't improved the issue either.
Any advice would be fabulous!
@SunsetRunner Thank you for getting back and trying the troubleshooting steps shared above. Since the issue persists, I'll send your case to our Support team so they can investigate further and provide a solution.
You will receive an email from them soon.
Let me know if you have any questions! ![]()
Best AnswerI have the same problem playing DEEZER. the + and - buttons are very small and no longer work with the finger on the screen. this has always worked well before! Help!! Has there been an update or something.
Best AnswerRestart your Versa 4-6 times in a row by pressing and holding the left and lower right buttons untill you see after each restart the Fitbit logo and release the buttons. Do not help with me.
Best AnswerHi, I have the same issue. Please help! I have reset several times but it makes no difference. I also changed the clock face which did nothing either.
Hi @Yamsy, thank you for joining us in this thread and our Fitbit Community. Since you mentioned that your Fitbit Versa's touchscreen won't swipe either, I appreciate the time spent trying to get this issue resolved before contacting our forums.
I'd like you to try a factory reset. To do so on your device, follow the steps below:
Keep me posted on the outcome.
