Hi Fitbit team & other community members,
I just got my Fitbit Versa yesterday. Started using the very same day. Today is my 2nd day of usage and I have started noticing anomalies in its stats tracking. Issues which I have encountered so far:
I changed my fitness tracking gear just because I thought that Fitbit would provide better metrics as it started with health tracking as prime objective but it is not meeting my expectations.
I am currently on latest firmware i.e. 32.32.12.19. I have few questions to Fitbit team before I take my final decision on leaving fitbit community and returning my Versa for final:
Looking forward for a genuine reply from Fitbit team.
@rockinfuture Welcome! It's good that the community is growing! Sorry to hear about your issues with your new Versa.
1.- Your tracker will detect the movement on your arm and translate that movement into steps. There are situations in which your arm may move but you won't be actually walking. This may happen when you are playing the drums, burping a baby or clapping. It can also happen when driving. You can negate these steps by logging a driving activity. You can try wearing your tracker on your non dominant hand but select that hand as dominant on the tracker’s settings to make it less sensitive to movement.
2.- You can try these suggestions to improve the heart rate reading. Also allow a few days (ideally a few weeks) to feed enough information to your account but I understand that this may not happen as it depends on you choosing to keep the Versa or not.
3.- Your device uses it's altimeter to detect variance in altitude. It will count 1 floor for every 10 ft it detects you climbed. There are situations that may affect the floor count like stormy weather (that has an actual impact on atmospheric pressure), gusts of wind, an AC unit in a close room or opening a door. I suggest you start by cleaning the back of the tracker with cotton and rubbing alcohol then use compressed air at a distance to clear the altimeter's opening. Finally restart it.
4.- As you mentioned your calorie burn depends on your activity and heart rate.
Regarding the steps counted while charging. This isn't happening to all Versas but the issue is being investigated and hopefully a solution will be released. I don't have any specific timeframe but you can check this thread for updates.
Let me know how it goes!
