01-08-2021 09:13
01-08-2021 09:13
I called customer service and changed my setting from sensitive to normal. Nada. I called again and they had me sync, reset, and forget device, and pair. Nada. I think it's really odd that my sleep score stopped on January 1st, 2021. I've had my versa a couple of years and no problem. Anybody have any ideas? Has this happened to you? Please help.
01-08-2021 09:26
01-08-2021 09:26
I have the same problem. Does your sensor lights work on the back of your watch?
Best Answer01-08-2021 09:26
01-08-2021 09:26
Best Answer01-08-2021 10:10
01-08-2021 10:10
Yes, it blinks green when close to my skin. Turns dark away from it.
Best Answer01-08-2021 15:38
01-08-2021 15:38
I have the same problem and the lights have stopped working on the watch!
