05-19-2019
18:33
08:16
LanuzaFitbit
05-19-2019
18:33
08:16
LanuzaFitbit
My Fitbit versa is tracking my daily walking around work as swimming. Does anyone know why?
Moderator edit: Clarified subject & Labels
05-20-2019 16:56 - edited 05-20-2019 16:58
Have you tried using the manual mode called walk? This should record correctly.
If you do not swim have you disabled the auto detect of swimming? I would also disable any other exercises not likely to be done. This will also speed up and make the tracker snappier.
05-20-2019 08:14
05-20-2019 08:14
Welcome to the Forums @Brelynn.
Let me help you figure out what is going on. I will be moving this thread to the Versa board as I think it is better suited for it.
In this case, I'd like to recommend that you try log out of your account and then log back in to make sure that the information loaded on the servers is correctly loaded.
In addition to that I'd like to ask you the following:
I look forward to your reply.
Best Answer05-20-2019 14:04
05-20-2019 14:04
Hello. Yes I've tried logging in and out.
It is showing up on it's own under the hexagon of weekly exercise automatically. I've looked for ways to change it with no luck.
Out of the 14 days I've had it 11 of them show swimming one shows weightlifting and one shows walking
Best Answer05-20-2019 16:56 - edited 05-20-2019 16:58
05-21-2019 09:44 - edited 05-21-2019 11:18
Hello @Brelynn and @Rich_Laue.
Thanks for being around to help @Rich_Laue! @Brelynn Thanks for answering my questions.
@Brelynn Please do let us know if the solution proposed by @Rich_Laue helped you out.
Feel free to let us know if you have any further questions.
