09-01-2018 13:55
09-01-2018 13:55
I have set 4 different alarms to wake me up etc, but they aren’t working. I don’t get any alarm.
please advice
09-01-2018 18:05
09-01-2018 18:05
Hi @Psdahri I'm sorry to hear you are having trouble with your alarms. You can verify you are setting the silent alarm correctly in the Manual on page 33. If everything is set correctly, but your silent alarm is still not working, I'd suggest contacting Customer Service.
09-01-2018 18:05
09-01-2018 18:05
09-01-2018 18:06
09-01-2018 18:06
Go to your alarm app on the Versa and remove all alarms. Then restart your Versa several times. When you have done that go into the alarm app again and reset the alarms. Let us know if that fixes it.
Just checking, does the Versa vibrate at other times? Or is it justvthe alarm it is not vibrating for?
Helen | Western Australia
09-02-2018 06:58
09-02-2018 06:58
