Versa and SpO2 clock face tip
In order to get new Sp02% to register after sleeping with it on my wrist last night, I had to restart my Versa (original version) in the morning. Now all functions show on clockface.
6 REPLIES 6
Hi there @harwax1, welcome to the Community Forums. I'm glad to hear that you finally got the SpO2 clock face for your Versa. Thanks for sharing what worked for you in order to get it.
To make sure your Fitbit device successfully measures your SpO2 values, keep the following in mind:
  • Your device doesn’t retroactively measure your SpO2 values. After you install the clock face, you’ll see dashed lines until after your next sleep session.
  • Charge your Fitbit device to make sure it’s able to collect data throughout your entire sleep session. Note that you may have to charge your Fitbit device more often when using the SpO2 Signature clock face.
  • Your Fitbit device must sync with the Fitbit app before the clock face updates. Note that it may take around an hour for your SpO2 values to appear after you sync your device. For troubleshooting syncing, see Why won't my Fitbit device sync?
  • Turning off any clock face permissions can cause the clock face to stop functioning. To check these settings:
    1. With your Fitbit device nearby, open the Fitbit app on your phone or tablet.
    2. In the Fitbit app, tap the Today tab > your profile picture > your device image.
    3. Tap Clock Faces.
    4. Tap the SpO2 Signature clock face.
    5. Tap Permissions. Turn on any permissions you turned off.
    6. Tap Details when you're done making changes.
  • Your Fitbit device must be able to consistently track your SpO2 data:
    • Wear your device slightly higher on your wrist.
    • Make sure your device is in contact with your skin.
    • Your device should be snug but not constricting.
    • Tattooed skin can impact the accuracy of the red and infrared sensors on your Fitbit device.
For more information about SpO2, see: How do I track blood oxygen saturation (SpO2) with my Fitbit device?
Battery level would be a great addition on clock face
I’d love to see weather/temperature, too.
Hi there,
i installed the spo2 clockface on my versa2 and the first night/morning i got an spo2 reading but since that every day i get a "couldnt read spo2" message.
tried reinstalling and checking all permissions but no luck.
any tips please
michael cook
Best I can say is assuming you restarted both cellphone and Versa watch,
the only other logical thing might be to check wrist placement and also
maybe switch wrists. Good luck
Virus-free.
www.avast.com
<#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
Hi there,
many thanks ! I hadn’t restarted my watch!
now restarted and all’s well - including me according to my Spo2 reading!
