08-04-2020
17:45
10:47
AlvaroFitbit
08-04-2020
17:45
10:47
AlvaroFitbit
My FitBit Versa battery dies so quickly now. In Less than 24 hrs It is dead. Any suggestions? Can you replace the battery on Versa?
Thank You!!
08-09-2020
10:28
07:08
08-09-2020
10:28
07:08
@Angeldesigns Welcome to the Fitbit Community!
Let me help you with your Versa battery draining quickly. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. You can follow these instructions to help improve the battery life.
I also moved your post to the correct board.
Let me know how it goes.
Best AnswerMine has started doing the same! It died fully for the first time last night and I charged to 100% - then I woke up this morning and it was still full but then fully died again an hour later. Have you found a solution? Fitbit are not very helpful at all ☹️
08-24-2020
07:38
07:09
08-24-2020
07:38
07:09
@SianPeters It's great to see that you've visited the Fitbit Community!
Let me help you with your Versa battery not lasting. Did you try the suggestions in my previous post? If you haven't then give them a try.
I look forward to your reply.
