06-13-2022
10:16
10:21
06-13-2022
10:16
10:21
Hello. My Versa 3 (Fitbit 3.60) has a blank screen. It appears to still be tracking data. It will synch. But the watch is not responsive to pressing buttons. Any thoughts? Thanks
06-13-2022 10:22 - edited 01-05-2024 13:43
Hi there, @Blankyscreen. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa.
Please restart your Versa as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
We hope that helps.
Best Answer06-13-2022 10:22 - edited 01-05-2024 13:43
We hope that helps.
Best Answer06-13-2022 10:43
06-13-2022 10:43
I am having this same issue on and off since 6/3. These restarts do not work
Best Answer06-13-2022 10:46
06-13-2022 10:46
Thanks. The restart doesn’t do anything. I can no longer change clock face because one of the recommendations was to forget the device, which I did. But I can’t pair the device because the app tells me to enter the pin number displayed in the versa screen. But the versa is blank !
Best Answer06-13-2022 11:11 - edited 11-16-2023 02:29
@Blankyscreen @MamadaurusReck I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
