05-08-2018
15:39
09:07
AlejandraFitbit
05-08-2018
15:39
09:07
AlejandraFitbit
So, my screen just went dark. The heart rate light in the back is on, the watch still buzzes with notifications and it still sends sync data to my phone. I tried the manual restart because that worked once when this happened before. But not any longer ... Anyone have ideas?
Best Answer05-08-2018 16:42
05-08-2018 16:42
@Zaelel wrote:So, my screen just went dark. The heart rate light in the back is on, the watch still buzzes with notifications and if still sends sync data to my phone. I tried the manual restart because that worked once when this happened before. But not any longer... Anyone have ideas?
Only two things left. Do a Factory Reset back to out of box condition and/or contact Customer Support. If you want to try the Factory Reset, swipe left to Settings, touch About and touch Factory Reset. Customer Support.
05-09-2018 09:09
05-09-2018 09:09
A warm welcome to the Community @Zaelel and @SunsetRunner thanks for stopping by.
I appreciate the efforts in trying to fix this issue and would like to know if you have followed our friend's recommendation and contacted our support team, have they offer you a solution for this?
Hope to hear from you soon. ![]()
05-09-2018 09:18
05-09-2018 09:18
Thanks for following up with me! I did give the support team a call. They were wonderful. The support team was unable to resolve the problem. But after I sent them a video of a failed factory reset, they announced it dead on arrival. After I ship it in the team offered to replace it.
05-10-2018 04:12
05-10-2018 04:12
Those are great news @Zaelel, I am glad to hear that you will be receiving a replacement. At the moment of receiving, you just need to do the following from your Fitbit app to set it up:
Happy stepping! ![]()
05-29-2018 06:40
05-29-2018 06:40
I have a similar problem this morning. After charging (?) over night, the screen is entirely blank, and unresponsive. One green light occasionally flickers on the back. Perhaps it didn't charge, but that would be unprecedented. I notice a firmware upgrade is pending and wonder if it were botched.
The device is less than two months old. This is annoying,
05-29-2018 06:47
05-29-2018 06:47
06-20-2018 03:32
06-20-2018 03:32
This morning my Versa watch face went blank. I can see that it is syncing with my iPhone, but I can't see anything on my Versa. Please help and advise.
LN
Best Answer06-20-2018 04:50
06-20-2018 04:50
Best Answer06-20-2018 08:16
06-20-2018 08:16
Many thanks but nothing helps. At least it still syncs with my iPhone.
My son is going to take it back when I see him. Shame, he gave it to me for Mothers Day this year.
Best Answer06-20-2018 08:38
06-20-2018 08:38
06-20-2018 23:34
06-20-2018 23:34
Thanks for the info, Realist.
I will ask my son to restart the Versa. If not successful, he will take it back to to store.
Fortunately, I can still see all the data on my iPhone.
Hope all goes well with your new Versa.
Best Answer06-26-2018 07:20
06-26-2018 07:20
Same thing just happened to me. Should it happen again, try placing the fitbit on the charger. The display came back the moment I put the versa on the charger. Battery was at 93% so the problem didn't initially stem from a depleted battery.. Hope this helps.
Best Answer06-26-2018 08:36
06-26-2018 08:36
06-26-2018 10:13 - edited 06-26-2018 10:13
Exact same thing with mine, I could see everything on my Galaxy, but not on the Versa screen. The display died. I worked with customer support on Saturday and sent it back yesterday, it's going to be a long few weeks...
Best Answer06-26-2018 11:06
06-26-2018 11:06
06-26-2018 17:00
06-26-2018 17:00
I only sent back the device. I kept the wrist bands and charger. Fitbit has always been very helpful when I've had issues.
Best Answer07-18-2018 19:44 - edited 07-18-2018 20:07
How do you do a factory reset if you can't see the screen?
07-18-2018 21:05
07-18-2018 21:05
Best Answer07-19-2018 06:58
07-19-2018 06:58
@ELLIEMAYo wrote:How do you do a factory reset if you can't see the screen?
Follow the instructions below, Ellie:
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time or otherwise don't follow the procedure precisely , the Fitbit logo reappears quickly and boots without factory reset.
IK you can't get it to work on the first try, try again several times if necessary. It is a bit tricky. Good Luck!
