Versa button has stopped working
ANSWERED
My versa back button is not working can not even set. Up my versa after a factory reset plz help
1 BEST ANSWER
Accepted Solutions
Hi there, @Sid0089. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa before reaching out.
Please try to remove dust or dirt by gently using a toothpick around the button. If this does not improve the button performance, you can try to clear debris using canned air, just hold the tracker at arm's length and spray once to loosen any dirt or dust that may have accumulated around the button. Then, please try restarting your Versa by following these steps
1 REPLY 1
