05-20-2020
03:16
05:27
JuanJoFitbit
05-20-2020
03:16
05:27
JuanJoFitbit
My Versa has been working fine up until about a week ago. I've had my fitbit for almost exactly a year (Mothers day 2019) The buttons/motion on stopped consistently working and when they do the touch screen only works 50% of the time. I've done the hard reset multiple times, and sometimes it works after that, but usually not. Help! I miss my fitbit!
Moderator edit: format
07-02-2020 05:25
07-02-2020 05:25
Hi @ETruck, welcome to our Fitbit Community! I'd like to follow up and help you with your Fitbit Versa since the buttons and touchscreen are not working properly. By the way, thank you for troubleshooting this issue before contacting our forums.
Please try cleaning around the buttons with a toothpick in order to remove any dust or moisture that get accumulated in these parts of the watch. Also, try a factory reset. To do so on your device, follow the steps below:
Keep me posted on the outcome.
