My calories was at 2100 something after doing a 45 min run and says I only burned 165 calories and then dropped total calories to 1900 something and then a few minutes later down again to 1800 something. I worked hard to burn those calories. Why is this happening?
Prior to: I added my workout manually, then synced.
Calories on watch and phone reduced.
@KimLynnB Welcome to the Fitbit Community! I hope you're doing well! Sorry for the delay in my reply.
Let me help you with your reduced calories on your account. Has this happened before? Did it happen with other logged activities? I suggest you allow your Versa to track your activity either using the activity mode on the Versa itself or using the SmartTrack auto-detection option. When you log your activity manually it may not share the same data as the activity recorded for that period with your device so your data may change.
Let me know how it goes.
