05-25-2018
08:50
07:49
AlejandraFitbit
05-25-2018
08:50
07:49
AlejandraFitbit
My Versa can't do the firmware update. My Versa can connect to my WiFi but even when I close the page of WiFi, he disconnect to WiFi. What can I do?
05-26-2018 13:43
05-26-2018 13:43
I'm not sure if I understand @jellertdep
Are you having trouble setting up the wifi on the versa? Is the Versa plugged in an charging? It needs to be for the WiFi to stay on .
As for updating the firmware, this can be done through Wifi or Bluetooth. I'm not sure what device is being used to update the firmware.
05-27-2018 07:51
05-27-2018 07:51
A warm welcome to the Community @jellertdep and @Rich_Laue thanks for stopping by.
If you are having issues connecting your Versa to your WiFi, I recommend taking a look at the help article Why won't my Fitbit watch connect to Wi-Fi? and follow the instructions provided there.
I hope this helps, let me know the outcome.
05-27-2018 14:06
05-27-2018 14:06
Hello
I always get this screen even when versa is charging and even when i'm nearby the router.
05-28-2018
09:09
06:05
05-28-2018
09:09
06:05
Thanks for the update and the attachment @jellertdep.
Please try the following:
If you still can't connect your watch to Wi-Fi, continue by doing the following:
Remove your watch from the list of Bluetooth devices on your phone (known as "unpairing").
Hope to hear from you soon.
12-10-2018 18:04
12-10-2018 18:04
This is so frustrating. I have just received a new Fitbit Versa and I can't make it connect to my WIFI. It is trying to connect then failed with a big red X mark on the fitbit screen. I have read this forum and tried many below tricks and it still doesn't connect. I may have a defect Fitbit Versa shipped to me.
I tried:
- rebooted my phone
- rebooted the Fitbit Versa many times
- reinstalled the fitbit app
- deleted the bluetooth pairing with the Fitbit and rediscovered it.
12-10-2018 19:40
12-10-2018 19:40
@sn305 have you checked to make sure the watch is compatable with your wifi?
How do I find my Wi-Fi network password and security setting?
Is the versa plugged in and charging, the wifi won't be turned in unless the versa is charging.
Does the Fitbit app give an error?
Deleting the Versa from the Bluetooth is a good step, but the user is not able to rediscover the Versa, this mouse be done by the app during the next sync.
12-22-2018 16:59 - edited 12-22-2018 17:00
Rich, thank you for the tips. Those information and links did help. However, there is also another tip that I would like to share here in case other will need. It worked for me.
The possible issue is most of the nowadays WIFI router has 5G and 2.4G WIFI bands. For Fitbit or Versa specifically, it can only connect to a 2.4G WIFI with N-band. You will need to connect your smart phone with the 2.4G WIFI first, and use the Fitbit APP on your phone to update the Fitbit Versa. I found out this the hard way and it took me 5 hours to figure this out as my phone was connected to the 5G WIFI band. The WIFI band connection will need to be compatible with your phone vs Fitbit. Hope this helps.
12-28-2018 03:48
12-28-2018 03:48
How do you find and change the Wi-Fi band you are connected to?
12-28-2018 06:41
12-28-2018 06:41
@Gshgma are you asking about your home router Wifi Setup?
Usually this is found on the back or bottom of the router.
Let's click on the Fitbit Help Link that is found below, a quick search of the word wifi will give us this hit.
12-28-2018 08:52
12-28-2018 08:52
12-28-2018 09:46 - edited 12-28-2018 09:49
Hi, in order to keep your Versa connected to WiFi, it needs to be in the charger and connected to PC during the entire update process. After that, go to your Fitbit app - go to WiFi settings - click on it - your network should be present there. When it is and you have entered the password of your router manually (Capital sensitive) earlier, there is on the right side of the name of your network a white icon. Click that and Fitbit starts connecting to your network. When the connection is completed the white icon turn to blue and it says "connected". Why is it necessary for the Versa to be in the charger and connected to PC? The Versa itself does not have WiFi on it's own but uses you phone/PC as a bridge to connect to the WiFi network. Whenever you take the Versa out of the charger, WiFi will be disconnected within a very short time. Hope this helps.
12-28-2018 10:21
12-28-2018 10:21
Fitbit will only connect to the 2.4 network. You just need to have the tracker charging, this can be done through the computer as mentioned he @SunsetRunner or your phones charging brick.
12-29-2018 17:36
12-29-2018 17:36
Since the post, I was able to get my versa setup.. I did nothing different then I had done in the beginning.. but as a note, i did not have the versa plugged into my computer to charge but rather into the wall...
i hope since it now it now sees the network, it will continue to do so.
thanks everyone.
12-29-2018 17:40
12-29-2018 17:40
Hi. let me know if my suggestions worked for you. For me it does all the time. Once again, if you want your Versa to be connected to WiFi, put and leave it in the charger and connected to PC als long as you need the Versa to be connected to WiFi (f.i. for transferring music or whatever). Once you disconnect the versa from your PC the WiFi connection is lost within no time.
12-29-2018 20:31
12-29-2018 20:31
Appreciate your info and found if informative.
Is my Versa supposed to stay connected to my wifi via my iPhone? Because I have to manually force it to connect to my wifi through the phone app. each time.
12-30-2018 04:41
12-30-2018 04:41
thanks everyone.
05-03-2019 13:34
05-03-2019 13:34
I know this post was in 2018 and we are now in May 2019. Took me the longest and could not connect the WiFi to my Versa. FINALLY! I connected it to my HotSpot and it worked. Hopefully this post will save someone hours out of their day.
05-04-2019 03:28 - edited 05-31-2019 08:03
So what was the final solution in getting the Versa connected to the phones hotspot?
05-31-2019 01:53
05-31-2019 01:53
Hi, can you tell me how you connected it to your Hotspot? I tried everything.
Set all the wifi on 2.4ghz. Still need to keep filling in my password over and over again. Network is out of reach.
